Service
Und noch ein weiterer Beitrag dazu:bigmac hat geschrieben:search help: hand brake low fluid replace warning
You Will Need:
Replacement handbrake switch
10mm socket/spanner
Torx screw driver (T20)
Symptoms
On D9 models, there is a common fault where this error message is displayed. It is usually caused by a faulty handbrake switch
Removal
New handbrake switch
Remove bolts (10mm) from both sides at the rear of floor console (either side of rear ash tray).
Remove screws from trims on both sides at front end of floor console (in foot wells)
Carefully pull side trims away from floor console, being careful for any vent ducts attached.
Open ash try and gently pull ash tray complete and surrounding trim away, gear lever gaiter will now also gently pull away
Using a plastic spatula, carefully prise switches from floor console, make note of plug locations, and unplug switches
Remove 2 x screws (T20) and nuts (10mm)
Carefully pull floor console upwards from rear end, and push front end down. Carefully pull floor console towards rear of car, being very careful for wires connected to cigar lighter. When there is sufficient clearance, unplug cigar lighter and fully remove floor console.
Gently pull handbrake rubber boot away from lever.
Remove nut (10mm) from handbrake cable (B) and pull up hand brake. Remove connector from handbrake switch (A) then unclip switch and remove it.
Refitting
Refit all components in reverse order
Quelle jeweils: http://www.peugeot406coupe.comTrafficBandit hat geschrieben:A common problem with our cars is the "Low brake fluid" warning appearing when you pull the handbrake. This warning appears even while the brake fluid level is ok. In that case a faulty handbrake switch is the problem and you need to replace the handbrake switch. A new handbrake switch will cost you about 3.15 euro but the fitting takes quite some time and when you leave that to peugeot it will cost you a lot more. You can also do it yourself and I decided to replace the handbrake switch today because I have this problem for the second time now. I took some pictures so all the members can see how to do it yourself.
First you will need a new handbrake switch. They can be ordered at any peugeot dealer and shouldn't cost you much.
To reach the handbrake switch you will need to remove the center console first.
Pull out the piece of plastic under the handbrake with a screwdriver
Next remove the ashtray by gently pulling it out.
You can now remove the leather around the gearstick
The front sidepanels are connected with two screws, remove them and take the sidepanels out
Now the sidepanels are gone you can take out the air outlet pipes
Before you can remove the mid console first disconnect the wiring of the electric parts.
The mid console is connected with 4 bolts
Gently remove the mid console
Remove the plastic piece behind the handbrake
Remove the rubber cover that's around the handbrake
Finally it's possible to see the handbrake switch
Disconnect the wiring and remove the switch
The old and the new one
You can now place the new switch and follow the same procedure the other way around. Before you put everything in place connect the wiring of the electrical parts and check if everything is working ok.
If everything went ok you should end up like this, problem solved
